1973dusterkid
Watch This
I have an almost complete 318 68 model.
The engine has been cleaned up some and Looks good. It has a 2bbr intake carb. Has an almost newdouble roller timing chain and center sump oil pan.I ran the engine had good oil pressure but backfired because of a burn valve so that will need to be fixed.You will need oil pump water pump and fuel pump and other small stuff.It also needs new gaskets.It is missing the distributer.It has a steel crank in it.The block was cracked in the water jacket but the machine shop fired it.They said it would be fine.
I am looking for 150 obo and do not want to ship this.Also trades
It has been cleaned more then what you see in the pictures.
