Charger440
New Member
I have a 1977 dodge m400 motorhome with a 440 and automatic 727. This motor and transmission has been a dream to own since I was a child. My plans are to install the motor and transmission into the ultimate build of a 1969 Charger R/T and convert the auto 727 into a standard.
I am currently have issues with the alternator belt. Last night I replaced the plugs, cables, cap and rotor. Sparks are gapped at .035. A couple weeks ago I replaced the "behemoth" of alternators. I am new to mechanics and have been self taught.
When starting up, the Belts scream and there is a ticking noise coming from the alternator as if it were hitting something. Belt shakes bad at idle but straightens out during Rev. I have checked and checked again, the alternator is not hitting anything. Neither is the bracket. I was advised to tighten the belt. When doing so at idle it looked much better. During high Rev suddenly I smell something burning. I look down at the Belts, and the alternator belt had twisted and nearly came off the crank pulley. Got rather chewed up. What did I do wrong? Was the belt in the wrong groove on the alternator? Too tight?
