Alternator out put.
Electrical and Ignition
  1. chad72duster
    chad72duster Well-Known Member
    667
    0
    May 22, 2004
    Perdido, AL
    Local Time:
    11:00 AM
    Ok I am not getting an Alt output on my 68 dart. The alternatotr only has a single Field output and a battery out out. I check the fusible link and its good, leads me think Alt or voltage Regulator . any inputs???
  2. superdart
    superdart A little misguided...
    1,139
    5
    Aug 26, 2004
    Arlington, Texas
    Local Time:
    5:00 AM
    Where are you measuring the voltage at? I found out my problem was a bad amp guage. All the current runs through it, if it's bad, nothing gets to the battery. Jumpering it with a stought 12AWG wire will tell you.
  3. chad72duster
    667
    0
    May 22, 2004
    Perdido, AL
    Local Time:
    11:00 AM
    it was the Alt like I thought. I checked continuity from the Alt to the starter realy and knew that like was good. The power runs from the Alt to the amp- meter and then to the starter relay through the fusible link. So when i checked the line from the alt to the starter relay that tells you that all of that is good. I kinda thought it was the Alt but never know with thes things.
  4. HawaiiDuster
    HawaiiDuster Well-Known Member
    2,601
    62
    May 22, 2004
    Honolulu & Las Vegas
    Local Time:
    3:00 AM
    You might want to upgrade the regulator if its still using the old style.
  5. six pack
    six pack Well-Known Member
    424
    0
    May 22, 2004
    Alberta Canada
    Local Time:
    11:00 AM
    You can get an electronic one from MP, probably elsewhere too. But I bet you already knew this.
