There is two. I don't see any another wire that would connect to the light blue wire. Where would be good location to tie it in?Thanks
I'm thinkin there should be two terminals in the alternator connector. Use your meter check there should be continuity, low resistance between the two, and NO continuity (open) to the case
(LOLOL I can't keep track of what you guys all drive)
