[FOR SALE] Aluminum SBM Bellhousing
jos51700
Green Bearing thread connoisseur
Bel-Ray
I've had this bellhousing forever. I think it's a truck housing since it has the timing window. Trans pilot hole is 5 1/8" but this DOES NOT FIT Overdrive/A-833. This MAY fit NP435 as mentioned below.
$50 plus actual shipping to you. Trades considered.
Thanks
John
trns mounting patterns are different . could be redrilled i would think , if there is enough bossing to do threads .
I could be wrong, but that looks like a NP435 bell. They also had the 5 1/8 hole.
Welp, you are correct. This does not fit an A-833 as I was told and have assumed for the last fifteen years.
It does look a bit beefy on the driver side.
Any issue with an older A-833 trans?
I think you could redrill it but the bosses don't line up with the A-833 very well
As asked in a pm, I cannot find any casting numbers on this bell housing
Thanks. I’ll have to pass them.
Much appreciated though.
