Hellooooo FABO!
in an attempt to keep fuel lines away from exhaust, i have run the lines this way. I'm thinking of building a box around the filter to protect it in case of rear U joint failure. I have another option but it runs the lines closer (@1") from axle over exhaust pipe. The U joint is forward of filter, but not much, and the drive line potentially could slide out of back of trans a little during the anomily. Whaddaya think gurus?
