AMC/JEEP 242 (4.0) Flywheel bolt pattern draw diagram or other Mopar engine compatible
PauloMDQ
New Member
Tito159357
Hello everyone, I need a flywheel for my AMC/Jeep 4.0. It is not available in my country and cannot be imported due to import restrictions. Apparently, the options would be:
A) find a compatible flywheel to adapt/reform from a Mopar car that is available in my country (Dodge Slant-six for example)
B) Make it from scratch in steel with a lathe operator
For both cases (make or adapt one) I need the diagram drawing with the measurements and distribution of the bolt holes on the crankshaft flange of the AMC/Jeep 4.0.
I am attaching some images, I got the diagram here in this forum and apparently it is from a slant-six, I didn't find one from AMC/Jeep:
Drawing / diagram o slant-six (apparently)
1LLxPPikHMW6zrChS3dyxFaOciCu3kHqj=s800
This is AMC/Jeep 242 4.0 crankshaft flange
1t8MZkXipSSQVrJTSH3Fb3DPztxu5mnqb=s400
This is a Slant-six (1972 up) crankshaft flange
1dXek7L2HH6fcpTGozo06DRIcdvk0ZQen=s400
Thank you very much for all your help !!
