Ammeter Bypass a Must?
Mopar General Discussions
  1. QuickDart360
    QuickDart360 Well-Known Member
    1,177
    425
    Apr 5, 2014
    San Antonio
    Local Time:
    12:14 AM
    Just have a question regarding ammeter bypass. I don't have a radio or high draw accessories that use alot of electricity. At one time my ammeter gauge petered out. The strip at the back burned and no more reading. No burned wires or bulkhead connectors, surprisingly!!! Also alternator is stock low amp. Question is is it absolutely needed to bypass or am I looking for trouble at not addressing this.
  2. xLURKxDOGx
    xLURKxDOGx "An angel fat, at satan's feast" FABO Gold Member
    3,884
    1284
    Dec 27, 2013
    PHX
    Local Time:
    10:14 PM
    It’s so painless in my opinion that there’s no real reason to not do it. Just another less potential problem to eliminate down the road.
    Jake
    • Agree Agree x 2
    • Like Like x 1
    • rumblefish360
      rumblefish360 So close, yet so far away FABO Gold Member
      38,404
      10025
      Jun 21, 2005
      New York, on a Island
      Local Time:
      1:14 AM
      There is no actual reason to do it. Some will post scary fire stories. And! While that is possible, so is winning lotto tonight.
      It is super simple to do this job. So, if you wish to do so..... your biggest issue is what gauge to get and where to put it.
      I wonder if they make one to replace the factory amp gauge.
    • 67Dart273
      67Dart273 FABO Gold Member FABO Gold Member
      43,618
      11145
      Oct 14, 2010
      Idaho
      Local Time:
      10:14 PM
      If you don't have a working ammeter I would do a bypass
      • Agree Agree x 3
      • MoparLeo
        MoparLeo NRA PATRON LEVEL LIFE MEMBER FABO Gold Member
        520
        314
        Feb 10, 2016
        Moreno Valley, Cal. So. Cal.
        Local Time:
        10:14 PM
      • 66fyssh
        66fyssh Don't Stop Believin' FABO Gold Member
        5,363
        4409
        Jun 22, 2013
        Northwest GA
        Local Time:
        1:14 AM
        I did the "fleet bypass" to eliminate high current from going through the bulkhead connector. The alternator wire feeds through a hole with a grommet beside the bulkhead connector.
        I figured it was a good compromise to keep a working amp guage and reduce the possibility of high resistance in the bulkhead.
      • QuickDart360
        1,177
        425
        Apr 5, 2014
        San Antonio
        Local Time:
        12:14 AM
        I forgot to mention my car is a 1975 dart sport. I don't know if this year is any different from other years as far as wire thickness to bulkhead and any other change based on year model alone? Hey 66 fyssh what is the fleet bypass? Now you have me intrigued!:rolleyes:
      • crackedback
        crackedback FABO Gold Member FABO Gold Member
        18,612
        2910
        Aug 7, 2005
        92201
        Local Time:
        10:14 PM
        It's good idea.
        • Agree Agree x 1
        • KnuckleDuster
          KnuckleDuster Well-Known Member
          1,746
          744
          Nov 9, 2005
          Texas
          Local Time:
          1:14 AM
          You can reach up under the dash without removing anything and move one wire so both are on the same post. Takes two minutes. If the gauge is fried anyway, why not just do it?
          • Agree Agree x 1
          • adriver
            adriver Blazing Apostle
            7,605
            4246
            Jun 1, 2007
            Where the red fern grows
            Local Time:
            1:14 AM
            1. If you have had a problem with the amp gauge bypass it. It is only there for you to see what's going on.
            2. it seem you know that even if you bypass the gauge by connecting the wires as has been suggested, you still are feeding through the bulkhead connector which is probably the bigger potential problem down the road.
            3. I've got a box of spare junk yard pull gauges for backup for my fleet, but I believe new ones are actually being reproduced now and would suggest if they are any good.
          • 67Dart273
            43,618
            11145
            Oct 14, 2010
            Idaho
            Local Time:
            10:14 PM
            You can find the "fleet wiring" in some of the manuals. This is a factory (or maybe dealer option) with the 60? or 65A optional alternator. "What they did" was to cut and tape one of the ammeter wires, then run a SEPARATE larger feed wire through a separate dedicated grommet in the firewall
            Go to MyMopar and download some factory manuals..........free
            MyMopar - Mopar Forums & Information - MyMopar Tools/Reference
            One place you can find example wiring of this is the 72 Plymouth manual, in the wiring diagrams they call it "65 Amp alternator--Satellite" on page 8-167
            New grommet and added wires at bottom of page
            • Thanks! Thanks! x 1
