Annoying Little Leak....
Shane
Ontario, Canada
Quick background,
When I got my car about two years ago, the tranny in it was VERY VERY sloppy to say the least. But I also go a bunch of parts with it. One thing was an aluminum OD833...
I use the car more as a driver then racer, so of course I rebuilt the OD(paid a locally well respected tranny shop to do so). So then the time comes when the clueless excited first timer has the motor and trans in, and low and behold the drive shaft doesnt go into the trans...
I had to change the yoke...which the OD tranny lucky(or I thought at the time) had with it...
Now My question:
I have a leak, its a drip at the rear seal of the tranny, where the yoke goes in..
I had the tranny shop look at it, and change the seal twice, but they are saying the problem is the slip yoke that goes in is Pitted, and thats what is causing my problem....
Does this make sense? To me it seems logical enough......just get a yoke thats good, and problem solved....I did my best to count the teeth on the shaft, and got 30, so I am assuming I need a 29 teeth yoke, thats not pitted and no more drip drip on my garage floor...lol
Does this make sense to you guys?
It will solve my problem?
Thanks,
Shane
i don't know if you can still get them but, once upon a tuesday you could buy a sleeve to go over the yoke to cover the seal land and they worked great.it was only about .010" thick. but it gave the seal lip a new area to ride.check at napa. they still use these things on big trucks and forklifts and such. check it out.hope this helps. good luck.
Thanks 340S,
The price seems resonible too, $68.
I counted 30 teeth on the shaft coming out of the tranny, So it seems that the 727 29 spline would work...
Its an OD aluminum Trans. I will pull the axle tonight to confirm before I order. Unless someone knows for sure...
Thanks,
Shane
A pitted yoke will definately cause leaking. Worse yet, people take sandpaper to them to get the rust off, and then they leak like a sieve. The yoke diameter is no longer flush to the bushing. Time for a new yoke.
