earthmover
in the tire smoke
hay guys I posted about getting new rings a few weeks ago and since then my buddy asked me why would I buy new rings when the rings on the pistons are still about new only about a total of 100 miles...I took 1 set off the piston for some reason when I took the motor apart but I can get a new set for that piston only if needed...what would you do?????I had the motor honed and new frost plug install and cam bearings since apart thats all....The motor would not run as I thought it would (cam timing/chain problem) but thta was it...so should I just get new for the 1 piston and buy a new cam and lifter set that I want to try, or all new ????I thought I would ask to see what kind of does and dont I get....8) street \ strip motor
