hotrod swinger
I drive from Sooke to Tofino today with a couple of detours, 343 km using 39.9 L. That puts me over 20 mpg for my slant.
We can’t get real gas at the pumps here anymore, unfortunatelyIs this eth/ meth infected gas or the "real thing?" The more alky, the worse the mileage
I convertedQQ: not trying to be a smart A$$….
You show the drive length in km and gas quantity in Liters. Did you convert behind the scenes to MPG or is your car from the states?
AJ in an engine that is run often it can be ok. Let it still in a carb for a month though and you will likely have problems- especially with small two stroke enginesIDK about all the hate for gasohol, in cars. I've been running 87E10 since 1999, nothing but, and I have had no trouble with it. Zero.
It was a good trip, not much traffic. I wasn’t babying it, just driving up and down mountains.That’s a good run! Were you moving along the Malahat or was it stop and go/crawl through that choke point? Hwy 4 can be a fun drive west of PA if you’re not stuck behind a camper van.
I’d be happy with that mileage too.
Yes there are definitely more mpg to be gained, I was not babying it lolNot bad at all sir. Depending on the weight of your right foot, there are likely more mpgs to be gained with further tuning.
E anything sucks, I always mix stabl with my 5 gal gas can for the lawnmowers, etc, every can.IDK about all the hate for gasohol, in cars. I've been running 87E10 since 1999, nothing but, and I have had no trouble with it. Zero.
Gasohol I haven't heard that in a while...IDK about all the hate for gasohol, in cars. I've been running 87E10 since 1999, nothing but, and I have had no trouble with it. Zero.
Higher humidity probaly is a factor, but I’m in a super dry climate.I have to LMFAO every time somebody tries to lecture how alky is no problemo, guaranteed they don't live where...... like here, the humidity was ~90% & 92°F a few days back.
If it isn't a "modern" fuel injection setup designed to use the ethanol gas, my stuff gets ethanol free fuel. Doesn't matter if it is $1.00 a gallon more. It still saves money and aggravation in the long run.E anything sucks, I always mix stabl with my 5 gal gas can for the lawnmowers, etc, every can.
One spring, after sitting thru the winter, went to push the pumper ball on the push mower, it stuck in.
Yellow-brown sticky glue crap thru the carburetor, nasty stuff.
Started running non-al 90 in any small engine ever since its only .25 cents more a gallon.
Yeah that came to an end here last August. Minimum ethanol content is now 5% even in the 94 octane from Chevron.We can’t get real gas at the pumps here anymore, unfortunately
