Another DIY gauge cluster
RAVano
Ct
Just finished up a DIY gauge cluster with New Vintage CFR series gauges. Below is a photo dump of the steps it took to get it done.
Now I’m working on cutting off the gear indicator and column shifter to clean things up a bit
I like it ! This is what hot rodding should be about. Building as much as you can by yourself! VS just buying stuff and your car winds up looking like everybody else’s .
Nice but I don't understand completely. Can you add some narrative to your photo series?
I’m not to good at explaining things. Just some photos of how I did it and what’s involved if anyone wanted to do it themselves. Kind of like IKEA instructions.
question from an old semi blind buzzard with trifocals. did you print out or modify the orig cluster part? i want to do something similar to that except i have 6 gauges. big speedo and tach and small oil, temp, volt and fuel gauges. thanks in advance.
I modified the original cluster. I wasn’t so worried about having 6 gauges because the volts read out on my FiTech handheld and also on the OLED screen of the Tach
Really great job. No options in the aftermarket for the long speedo guys. I ended up replacing the dash housing with a 73+ so I could get the dash insert from Autometer. It holds 6.
Hello hello. I just did my own DIY dash today on my 72 Dart Swinger. I used a Speedway motors A-body aluminum 6 gauge panel with Autometer Mopar gauges. It cost around 100 bucks for the panel if i remember correctly. The panel took some trimming to make it fit just right. Overall i was really happy with how the project went.
I have my entire dash out right now so it was easy removing the gauge cluster. I stripped it down, treated and painted the rust, and cut the gauge cluster. Once the gauges were separated from the plastic cover panel i mapped out the back of plastic cover with a sharpie and started cutting away material with a die grinder with like a 1.25” cutting wheel. It took about 2 hours to meticulously cut away material. Due to awkward angles of plastic molded bezels, the small cutting wheel i had played a factor with the time. If i had a slightly larger cutting wheel to switch back and forth with it would have made the process easier but i did what i could with what i had. Also heat was a factor, 50 year old plastic melts and smokes a lot easier than you would think. I definitely took my time making sure not to overheat the plastic. I left about 1/4” of material around the border of the original cluster cover to set the new aluminum panel against on the front side of the old cluster border. The aluminum panel did need to be trimmed to make it fit perfectly. I used a belt grinder to shave down the edges nice and evenly. I havent come up with a final solution as to securing the panel to the original cluster plastic but i think i will do a combination of Right Stuff RTV, and possibly some custom aluminum clamps bolted from 3 mounting holes in the panel to the cluster, i think they are like 10/32” holes. Will update once i cross that bridge but heres my progress so far.
That’s lookin good!
One tip I’ve heard (but never done yet) is paint the back side of your dash frame white. That way anytime you need to work under there, you can see things a lot better.
That’s lookin good!
Ahh I like that idea, I was thinking the exact opposite and was gonna paint everything black haha. I think ill go with white tho thanks for the tip!
I wanna do this too, but was curious does the speedo and tach being off set from the steering column seem to be an issue or weird while driving?
