flyboy01
Its almost done!
Ya,I needed this one like I needed a hole in my head to !
Holy shnikes! that is one fine looking ride. Great starting place for big block stroker.
My latest fight is with the wipers, the little plastic bushing for the wiper arms disintegrated, so now I have no wipers. I tried to use replacement auto store bushings, but they dont seem to fit, I am looking for suggestions. How hard is it to covert to the earlier clip style?
What cluster? THe stock one?
I have only had 1 quiksilver jam up on me. I bet it is in the detent on the driver side of the shifter. This one jammed if you went below drive into 1 or 2 and tried to manually shift. There was a little clip that had to be moved easily and then it was fine.
Glad to hear the car is coming along.
I then recovered the door panels. Since the old panels had huge speaker holes in them and there were some cracks and tears in the vinyl, I made some new panels out of 1/4" by tracing the old panels onto the new ones, cut them out with a jigsaw, attached foam, cut out a pattern I liked, then covered them, using Super 90 adhesive.
i was wondering what type of foam did u use, and where did ya get it at also what type of wood did u use?
actually I used 1/8 wood, and I used a craft foam that was 1/8", but I recommend doubling up or I should have just used more wood for the shapes. I got the foam, vinyl, abd glue at Joanne Fabrics. (yes...I felt gay walking in there, I was afraid somebody would see me)
