340plot
the bushy bush
i just picked this up last weekend, but money is tight, and i want to finish the 340 73 duster, so this must go.
here is a95% complete setup ready to drop in and go . it is a 318 and 4 speed o.d setup. 318 has cam, eldebrock intake, holley 600 cfm carb, ..... it has been rebuilt. it purrs like a kitten, and member i bought it from can vouch for that. comes with electronic ignition conversion, and everything from carb to oil pan. do need belts, altenater. everything else is there. the 4 speed needs the reverse rod, and a shift handle. that is it. everything else is there. the trans looks perfect, and clean.clutch is newer. this came out of a running driveing car less than two weeks ago. the is one broken stud on driver side head for ezaust manifold. it still sticks out some, so should be pretty eassy to get out. i have not had time to try.
1,100.00 for complete setup.
i am picking up a 72 duster 340 3 speed, so if you wanted like the floor shift column, hump, z bar, we can work out a special on all
located 30 minutes from martinsville international speedway in va
