mopar65
well i hope to in the next couple of weeks make some 1/4 mile passes with the new engine that i put in my 73 dart swinger. I look forward to seeing your answers. OK here is all the important info. thanks Mopar658)8)
1973 dodge dart that should weigh around 3400 pounds with me in it.
1973 0.030 over 440
wisco pro true forged flat top pistons that are at about 0.005 below deck
compression comes out to 11.1.1
Indy EZ heads bowl ported that flow 310-315 @ 0.600 lift
factory stock stroke steel crank
eagle rods
stock main caps with arp main studs
comp solid roller 264 @ 0.050 and 634 lift with crane 1.6 roller rockers
manton 0.0120 3/8 push rods
m1 tunnel ram and 2 750 carter comp series carbs
727 with crt racing valve body etc
9-1/2 dynamic 5200-5500 stall
8-3/4 with a full spool and 4.10 gears
brand new M/T Drag radials
mopar 03/04 super stock springs
mopar long 50/50 rear shocks
front will eather be the new calvert shocks or the summit version 3 way shocks set at 90/10
wel i hope that is enough info and if there is anything i left out please let me know and i will answer it the best i can. thanks Mopar658)
1973 0.030 over 440
eagle rods
