Any 2 stroke experts out there
General Discussion
  1. ike61
    ike61 Well-Known Member
    557
    178
    Sep 6, 2010
    minnesota
    Local Time:
    12:50 AM
    I have this coleman mini bike with a two stroke sachs motor. It runs great, but raw fuel drips out of the exhaust and makes a real mess.the gas is mixed 24:1, which is what is recommended. What could cause this? Thanks
  2. 512Stroker
    512Stroker We are all here because we are not all there.
    1,968
    1400
    May 30, 2016
    Freedom, MO
    Local Time:
    12:50 AM
    If it is fuel dripping out I would say you have a carb issue.
    What does the spark plug look like?
    2 strokes always run on the rich side
  3. ike61
    557
    178
    Sep 6, 2010
    minnesota
    Local Time:
    12:50 AM
    It will idle all day so i dont think its running too rich. The plug looks normal. I can run the hell out of it, but it still does it. I have an identical bike and that one does it too just not as bad
  4. George Jets
    George Jets 1967 Dart 2 Door FABO Gold Member
    3,856
    5428
    Jan 18, 2019
    Farmington MN
    Local Time:
    12:50 AM
    Needle and seat in the carb is leaking fuel past the seat, not shutting off the gas when the fuel bowls are full.
    Probably a piece of dirt stuck on the seat, clean the fines out of the fuel bowl and clean or replace the needle and seat with new.
    Also make sure the fuel bowl floats are set correctly to shut off the fuel when it reaches the proper level in the bowl.
    • Agree Agree x 2
    • Dicer
      Dicer Diceman FABO Gold Member
      1,212
      1674
      Jan 12, 2016
      Land of Lincoln
      Local Time:
      12:50 AM
      If you have fuel tank shut off valve use it, if not buy an inline valve. Sounds like raw fuel draining from the carburetor into the crankcase area where it sits until the engine is started. The fuel not being atomized will be force out during the exhaust stroke. If the muffler has an inner baffle take it out and shine it up on the wire wheel.....check float...check needle valve and seat.
      • Agree Agree x 2
      • George Jets
        3,856
        5428
        Jan 18, 2019
        Farmington MN
        Local Time:
        12:50 AM
        Yes, that inline fuel shut off in itself will probably cure it. Turn off the fuel when not running the engine.
        Clean out the bowl and needle and seat too.
      • ike61
        557
        178
        Sep 6, 2010
        minnesota
        Local Time:
        12:50 AM
        Ok. If the fuel was leaking past the seat, wouldnt it flood out while idling? I do shut off the fuel after each use because it will leak. It has a bing carburetor and i dont think the float can be adjusted. I will check on these ideas
      • famous bob
        famous bob mopar misfit
        18,386
        7751
        Aug 14, 2011
        okla
        Local Time:
        12:50 AM
        2 STROKES DO NOT ALWAYS RUN RICH as stated above , they run how they are adjusted/jetted . .
        I`d check the reed valve too--------------------------
        • Agree Agree x 1
        • 512Stroker
          1,968
          1400
          May 30, 2016
          Freedom, MO
          Local Time:
          12:50 AM
          You sure it not just condensation you see dripping.
          Collect some in a clear jar and see what you got
          • Like Like x 1
          • cudavert
            cudavert DARTAHOLIC
            2,806
            290
            Apr 16, 2009
            Hesperia, CA
            Local Time:
            10:50 PM
            If it was raw fuel, it wouldn't be running great. It would be flooded and barely running. I'll bet it's oil. My '75 Yamaha DT400 does that, drips oil out of the pipe.
            You could go up to 32:1 and lessen it....or even 40:1 or more.
            • Agree Agree x 4
            • 1994redram
              1994redram FABO Gold Member FABO Gold Member
              1,299
              719
              May 9, 2012
              Oklahoma
              Local Time:
              12:50 AM
              My Yamaha Banshee used to condensate really bad at idle. Revving it up would blast a nasty black water and oil concoction all over. And that quad was fast.
              I HIGHLY doubt its a carb issue. If the carb was bad enough to fill the intake, crankcase, cylinder, AND exhaust. It just wouldn't run....
              That's a cool bike with a sweet engine. I have a moped with a Sach's engine. Also have a Puch powered 'ped.
            • ike61
              557
              178
              Sep 6, 2010
              minnesota
              Local Time:
              12:50 AM
              Thanks. Yeah the kids love them because you dont have to shift. They are two speed automatic
            • ike61
              557
              178
              Sep 6, 2010
              minnesota
              Local Time:
              12:50 AM
              No its fuel/oil. Comes out at the end of the tail pipe, where the pipe joint is, and makes a damn mess
            • Bodyperson
              Bodyperson Pedal to the metal
              5,905
              8258
              Nov 26, 2015
              NW MONTANA
              Local Time:
              11:50 PM
              Im guessing blow by. Looks like the case is leaking too. Who cares. RUN IT
            • Kern Dog
              Kern Dog FABO Gold Member FABO Gold Member
              5,124
              8120
              May 23, 2010
              Granite bay CA
              Local Time:
              10:50 PM
              Any 2 stroke experts?
              Maybe ask some of the member's Wives!
            • Bodyperson
              5,905
              8258
              Nov 26, 2015
              NW MONTANA
              Local Time:
              11:50 PM
              Exhaust could be getting plugged and running rich. Might try lowering the needle in the carb. I've taken an acetylene torch to the exhaust and burned out the carbon. Make sure your neighbors aren't home . lol
            • AJ/FormS
              AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
              20,003
              7603
              Jan 19, 2014
              South-Central Manitoba,Canada, 900ftelevation
              Local Time:
              12:50 AM
              Looks like sooty condensate to me. I used to see that all the time when I was in the business of motorcycle repair; even brand new ones did it.
              When the engine runs right, the exhaust is full of water-vapor, as a byproduct of the energy conversion process. You can see it every morning in cool weather when you warm up your car.
              Your exhaust system is running too cool for too long. Suzuki solved that with dual wall pipes, and special clamps with impregnated wiremesh inserts, and underslung mufflers.
              For you, I recommend ;
              burning out the exhaust baffle
              a headerwrap on the frontmost vertical section,
              RTV sealer on the joints
              and set the idle-speed higher.
              The idea here is to keep the exhaust hot enough so the water vapor exits the system, instead of condensing and running back into the low parts. After the muffler fills up with water, it has no place to go but downhill, unless
              you blast it out by reving it up, or
              drill an exit hole, braze in a spigot, and rout the near boiling water away with a silicon hose.
              • Agree Agree x 1
              • famous bob
                18,386
                7751
                Aug 14, 2011
                okla
                Local Time:
                12:50 AM
                ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^agree
                But all 2 strokes will usually foul a silencer/muffler, and need to be cleaned . I just haqd to do it on my leaf blower , and had to do it on my old quadzillas.
              • mbaird
                mbaird mbaird
                6,655
                3393
                Dec 10, 2005
                boise, Id
                Local Time:
                11:50 PM
                Your getting drool... 24:1 seems way too much . But if that is recomended .... try a good synthetic oil like Motul and mix 40:1 .
                The reson your plugs look good at 24:1 is because the oil is displacing the fuel and actually leaning out the A/F . But the oil is not burning and running out the pipe .
                • Agree Agree x 3
                • AJ/FormS
                  20,003
                  7603
                  Jan 19, 2014
                  Local Time:
                  12:50 AM
                  That's right;
                  some of the oil, maybe most, goes out the pipe with the hot exhaust. But some condenses in the system and eventually plugs the spark arrestor, if equipped, and or the baffle.
                  In the past we removed the tuned pipe poured diesel into them, stood them up, and set them on fire. Later, we retrieved them, cleaned the outside, hit 'em with Hi-temp paint, and re-installed them;
                  instant tune-up.
                  • Agree Agree x 1
                  • yellow rose
                    yellow rose Overnight Sensation FABO Gold Member
                    27,246
                    23466
                    Jun 19, 2015
                    Central Washington
                    Local Time:
                    10:50 PM
                    THIS^^^^^^^
                    And when you get rid of all that oil, it will be fuel rich and you’ll need to do some jetting so it won’t foul plugs.
                    • Agree Agree x 1
                    • George Jets
                      3,856
                      5428
                      Jan 18, 2019
                      Farmington MN
                      Local Time:
                      12:50 AM
                      Yes, I run 50:1 in all of my 2 cycle chainsaws, never ever came remotely close to scoring a piston or burning a hole in top of one.
                      They run so much better on non Ethanol fuel too. Start way easier and run way better and more power.
                      The Ethanol fuel draws moisture just sitting in the tank and when you have the gas cap off, and in your gas cans too. Hence the moisture condensing back out dripping out of your cold exhaust pipe.
                    • krazykuda
                      krazykuda Well-Known Member FABO Gold Member How-To Section Editor
                      57,399
                      23045
                      Aug 20, 2007
                      Orland Park, IL
                      Local Time:
                      12:50 AM
                    • mbaird
                      mbaird mbaird
                      6,655
                      3393
                      Dec 10, 2005
                      boise, Id
                      Local Time:
                      11:50 PM
                      I run Motorex 2t Synthetic in that KTM ( notsure if you can see it on trailer) @ 50:1...
                      Forgot I had already mixed my oil on last tank and added more. Smoked like a banshee and drooled ! Didnt foul a plug though .
                    • ike61
                      557
                      178
                      Sep 6, 2010
                      minnesota
                      Local Time:
                      12:50 AM
                      Maybe they recommend 24:1 so kids didnt blow them up so easily??
