Any 2 stroke experts out there
Yes, I run 50:1 in all of my 2 cycle chainsaws, never ever came remotely close to scoring a piston or burning a hole in top of one.
They run so much better on non Ethanol fuel too. Start way easier and run way better and more power.
The Ethanol fuel draws moisture just sitting in the tank and when you have the gas cap off, and in your gas cans too. Hence the moisture condensing back out dripping out of your cold exhaust pipe.
I run nothing but 93 straight gas in everything but my Ram pickup.
run 40:1 in my polaris 4wheelers! check bottom of crankcase for a drain plug, use to drain all sorts of nasty outta my 4wheelers, specially after using as a submarine!
We encounter lots of water crossings here in the mtns. I change my trany oil every ride that takes me thru 2' or deeper. Every 5th ride regaurdless .
