Any anyone have experience with the Voodoo 20200711 roller cam?
Valkman
NC
If so could you tell me type on motor setup you have, and what part of characteristics you experienced with it
It would have been easier to list specs or do this---> Voodoo Retro-Fit Hydraulic Roller Cam - Chrysler 273-360 270/279 - Lunati Power
I just had a 4 week discussion with Lunati on a few things about that line of cams.
1: There not a retro fit cam because the fuel pump ecentric can not be used in any way shape or form, no way no how.
2; It took 4 weeks to get my money back on the cam because they said it was a retro fit cam.
3; Even though I produced pictures of there cam next to the proper length snout cam, they then claimed I got the wrong cam. Even though THAT is THE cam on there own web site.
A total of 8 weeks and dozens it of emails with pictures finally produced something.
IF you decide on that cam, Hughesengines has a trick part that will solve the problem.
Thanks for the heads up.
That’s interesting, I noticed that they have a cam for the early roller motor and they point out the long shaft for the eccentric. Voodoo - Hydraulic Roller (1985-92 W/ Long Snout, Mechanical Fuel Pump & Shaft Rockers) - Lunati Power
I'm running the 713 in my 408 with a mechanical fuel pump.
The reason I ask is because Lunati claims 711 is a good streetable choice, but the specs would equate it to be pretty wild in the flat tappet world. So I'm just curious on how it behaves in the real world .
Its in a pro touring duster with 3.23 gears. Took it to the track for a car show and made a "parade lap" , went 11.51 at 120 on Kuhmo street tires with a weak 1.83 - 60 . I left horsepower on the table by not going solid roller, super victor and 1-7/8" TTI's. So for a more streetable combo I used a ported airgap , small tube TTI's and of course the hydraulic roller. Has a QF 950 on top of RJ stage 2 ported heads with 10-1/2 comp. The combo worked perfect with the eddie heads stock valve springs. . The torque allowed me to use a dynamic 9-1/2 3500 stall even with the 3.23 gears. Its very reliable but I just use it for car shows and some spirited back roads driving.
Nope the stock Edelbrock springs are single with a damper , around 350 open I believe. Very close to what Lunati recommends. The motor would pull to 6500 but that's the max for the roller lifters so I set the limiter at 6200 and shift at 5800-6000
I asked because I bought a set of double springs from a guy who said he took off a set of new Eddy's he got. I read somewhere the these springs were for a roller cam application I believe the Eddy # is 5845
Could be , my eddies are over 5 years old but also someone else told me they are now making smallblock heads with roller cam springs already installed , might be worth looking into. Mine have been fine so far.
