Any good ears?
DERICKS
CLINTON TOWNSHIP,MI
can you be more specific?
sounds like you are just getting on and off the gas ?
The noise is very hard to detect...its only upon throttle application, it sounds similar to heat shield vibrating on a cat converter except i dont have one LOL! It doesnt occur at steady cruise speeds and it does it sitting still in park or nuetral.
It could be the converter bolts just on the edge of nicking.
With it being more right side predominent, im wondering about mechanical fuel pump.
I had an intermittent rattle. It was the arm on the fuel pump.
Good luck
I tightened the converter bolts....could the flexplate be cracked up at the crank and make a noise like this??? I dont have a mechanical fule pump on the car.
I had a flexplate crack on me,but it was on a GM(87 Cutlass with 350 s.b)the crack was bolt hole to bolt hole.Hope it,s not your convertor.Good luck.
^ As the folks already stated & you tightened ...
which begs the 'q', are the crank to plate bolts loose?
Course you can't see that, but 'run the build tape in your head'
(as it were)
As it sounds (now),noise is 'decel' only. so my next SWAG's (scientific wild *** guesses)would be ...
1) loose 'tin' (as the folks already mentioned)
2) loose right side motor mount /fasteners.
3) Trans mount / fasteners
= (again SWAGing) fan/ shroud contact on decel.
(as it were)
usausally the fan only would hit on accereration would'nt it?
