408 ci
eagle forged crank
ohio crankshaft rods
Icon 12.5 comp flat tops at zero deck
Comp solid roller
INT-.622 lift EXH- .589 lift
Duration @50 INT-258 EXH-260
@111.0 centerline
IMM prepped RHS heads with pushrod pinch porting & bowl work
1.5 Harland Sharp roller rockers
Melling HV oil pump
Dougs 1 5/8 headers(open)
Edelbrock RPM Airgap intake (Gasket matched)
AED 750 DP carb
open 1" spacer
Moroso electric water pump
MSD pro billet distributor and MSD ignition
Car is a 71 dart with a race weight of 3250 with driver.
powerglide tranny with 1.76 gear
4.86 rear gear
29.5 X 9 MT slicks
need more info, just let me know.
curious to see what you guys think the HP numbers will be, and what the 1/8th mile ET will be. hoping for 6.80's on gas, before switching to alcohol. thanks.
eagle forged crank
Comp solid roller
@111.0 centerline
Melling HV oil pump
AED 750 DP carb
open 1" spacer
4.86 rear gear
29.5 X 9 MT slicks
