[SOLD] any interest in a 67 v8 complete front suspension?
Sedanman
67-9 Valiant specialist
chicago Il
I am switching out my 67 Valiant v8 drum brake front suspension for the 73 & up spool with disc brakes & testing if there is any interest in it. It will be a complete bolt in assy with 273 motor mounts,brakes,control arms,ps box. pick up only in 60108 & the previous owner said he rebuilt everything but didn't replace the idler or pitman arms. It will need new shoes for the brakes. I am also switching the prop valve & brake lines & if I can get those off you can have that too. You can come test drive it before I pull it,make me an offer
I have a 340 & trans in the shop & will be swapping out the 273 motor,904 trans & exhaust as well but will be keeping parts off the engine. Then I will be swapping out the driveshaft & 7 1/4 rear. I am doing this in stages & will only pull & sell when all is ready for the swaps. The engine has 65psi in #6 cylinder,the others are 100+.
sale pending
