any problems fitting small block 727 tran into 69 cuda
6969cuda
mopar or no car
kelowna bc
just picked up a 727,and its matched with a smallblock 360,the car had the smaller 904 tran befour, i can see im gonna need to cut the drive shaft down, just woundering if ill need to do anything eles.
I had to modify dipstick tube, but thinking back, maybe all I had was a 904 tube, cant remember. Either way I just cut off mount tab, rotated tube and retacked. 67 car, should be the same. and I think the NSSwitch plug was different also. I believe you`ll need a large yoke and larger driveshaft built to size and balanced. thats about it. I`m rowing my own now so this is many years ago. If I missed anything, help em out guys8)
NSswith i have fits the trany so that not a problem, im gonna have to look at the drive shaft, and see if it fits the new trany, if not were would be the best place to find the thicker drive shaft, or what cars would have the thicker drive shafts,
