fenderman33
Does anyone here who's replaced a full quarter on a duster have any tips for the job? Will the flange on the sail panel slide out from underneath the roof seam once the welds are drilled? Is it also spot welded under the drip rail? Did you peel the upper trunk gutter up just enough to get the quarter off?
Any advise would be appreciated.
Thanks,
Jon
Thanks,
Jon
