eric202006
440 block .30 over
stock forged crank 10/10
forged h-beam rods ARP2000 bolts
hypereutectic pistons
ported 906 heads
windage tray
milodon oil pan
ARP main studs
pro comp head studs
pro comp offset rocker arms 1.6
pro comp shafts
ARP stainless intake bolts
Edelbrock RPM intake
viton rear seal
comp cam solid lift cam
Smith bros. push rods
SFI flexplate
fram filter
high volume oil pump
ARP oil pump bolts
aluminum water pump housing
dynoed at Shelton Racing Ent.
made 501hp 520tq
can drive anywhere
never been over 180 degrees
run 7.50 in a full body and interior duster street car.
make offer really trying to move.
ported 906 heads
windage tray
milodon oil pan
ARP main studs
pro comp head studs
pro comp shafts
viton rear seal
SFI flexplate
fram filter
ARP oil pump bolts
made 501hp 520tq
can drive anywhere
