MileHighDart
I'm doing a rebuild on a 1999 5.9 magnum from a Ram 2500.
I've been told that there are numbers stamped on the crank that will tell me
if any +1 or -1 bearings were used on this motor from the factory.
I guess you're suppose to be able to look these numbers up in the FSM and it will tell you.
Here's a few pics of the only stamped numbers I can find on the crank.
If anyone can decode these numbers it would be a big help.
If I cant figure it out, I'll just buy std size bearings and plastigauge them when installing.
Thanks
Thanks
