I've had success with this in the past.Looking to get my windshield & back glass trim off 70 dart so I can replace my roof skin
Pics & who makes it please & thank you.
thats my favoriteI've had success with this in the past.
OEMTools 25338 OEM Automotive Tools Window Molding Clip Removal Tools | Summit Racing
Cool thanksI've had success with this in the past.
Regardless of the tool, technique is the winner . cool mod."Tool" I use for window trim to pull the clip so it releases. Carpet knife with the tip reshaped on a grinding wheel.
View attachment 1715803492 View attachment 1715803493
I have one of those Ill give that a try before I buy the one rrr showed."Tool" I use for window trim to pull the clip so it releases. Carpet knife with the tip reshaped on a grinding wheel.
At some point, SOMETIMES, you can slide the molding off but can risk damage. Sounds like you need a new top anyway.I think I'm having an issue with the old vinyl top & the rust pushing up against the back of the trim so I can't get some of the clips to release.
Yeah, I'm going to try and rake out what's hindering the release of the clip, possibly try to pry lightly up on the bottom of the trim at the seam as I release the clip. Honestly I feel kinda like a clip is beating me after all of my mechanical skill.At some point, SOMETIMES, you can slide the molding off but can risk damage. Sounds like you need a new top anyway.
Ah that makes sense. Yeah sikaflex doesn't give up easy either. Well hopefully I can save the trim if not it's weight reduction lolA pudy knife wrapped in blue tape is used to lift up while the hook tool compresses the clip.
99.9 percent of the time the clip and or trim is glued on because some prior *** hat damaged the clip.
You are likely fighting the sikaflex.....
Thanks for the tipYou may try running a razor blade under the trim while lifting up with the puddy knife. That can help also.
I use to do auto glass as a kid and I glued a lot of trim and or clips back on........
