That is a genius idea :thumbrig:
I tried a similar thing with my car back when I was in high school. :idea1: I put double snorkels on my 2 bbl air cleaner & connected them with hoses to the cowl where the two removeable plastic plugs are (Early A). I ended up with a lot of gasoline fumes in the car. Maybe a carb rebuild would have helped things. disgust
Perhaps he blocked off the cowl air vents under the dash? With the vents intact, fumes would definitely be a problem (as you already pointed out).
