Anyone running M&H Muscle Car tires?
73Scamp318
Waterloo/Cedar Falls - IA
Is anyone running the M&H Muscle Car D.O.T. Drag Tires?
http://www.mandhtires.com/store.php?crn=73&action=show&show_products_mode=cat_click
http://www.jegs.com/i/M&H/676/MSS-002/10002/-1
I've been looking for a set of good street/strip tires for my Scamp and I'm currently stuck with 14" wheels, but I won't run the 14" slicks I currently have due to weather checking and I'm just tired of swapping the tires back and forth every time I go to the track.
Any feedback on these would be appreciated.
Boy does that name bring back memories. I ran M&H Racemasters eons ago. Didn't even know the company was still around. LMAO I think any tire made for street/strip duty with all the new compounds they have today will work for you. Good luck.
I looked into those for my Dart. I wanted a set for street driving with Coker Pro-Trac front runners to get 'the look'.
Then I was going to get another set altogether for when I take the car to the track - Moroso fronts and M/T drag radials.
That's like $2K worth of tires. :sad:
68383GTS: I just mounted a set of those. How do you like them?
Should have saved your money bfg drag radials are useless,m/t drag radials are probably the best out there...
Here's a related question. If the car is mostly street (95%) and occasional strip (5%) then which of the drag radials listed below is the best:
M&H?
BFG?
M/T?
Nitto?
M&H?
BFG?
M/T?
Nitto?
Choose one with decent tread for the street.
Well my GTS has a fresh engine with 425 HP I have not got to really try them out on the Dart.But I had a set on a 1969 1/2 Road Runner and they hooked real good.And then I put in a 496 stroker 500 HP and they spun like nothing.So in my opinion they are good up til 450 HP.But I never really heated them up first so if you heat them up I am sure they will work better.
Jim
Jim
Just wondered. Thanks 68383GTS.
