Anyone Seen an AGC 2 Amp fuse rated for 32 volt (not 250 volt)?
dibbons
La Paz, B.C.S., Mexico
I see in the fuse variety pack I recently purchased at Autozone, the smaller amp rating fuses are not the automotive 32 volt style, they snuck in some 250 volt (1 amp, 2 amp, 2.5 amp, & 3 amp). The '65 Formula S calls for a 2 amp instrument panel fuse and I'm sure it should be the 32 volt rated. Thank you.
Well, now you made me break out my magnifying glass! I have large display of Littlefuses. All my low Amp ones say 250v. I will follow discussion.
So far as I know higher voltage fuses in lower voltage applications are OK. So far as I know "the big thing" with higher voltage fuses is so that when they blow, they leave enough gap that there is no possibility of arc-over
Direct from wikipedia.
Rated voltage Edit
The voltage rating of the fuse must be equal to or, greater than, what would become the open-circuit voltage. For example, a glass tube fuse rated at 32 volts would not reliably interrupt current from a voltage source of 120 or 230 V. If a 32 V fuse attempts to interrupt the 120 or 230 V source, an arc may result. Plasma inside the glass tube may continue to conduct current until the current diminishes to the point where the plasma becomes a non-conducting gas. Rated voltage should be higher than the maximum voltage source it would have to disconnect. Connecting fuses in series does not increase the rated voltage of the combination, nor of any one fuse
2x32= 64 watts and
64/13.5=4.7amps
Your math is good but the fuse will pop if it has 2 amps at 5 volts or 12 volts or 30 volts or 60 volts etc. 2 amps is 2 amps.
Analogy...
Amps ( flow of electrons) would be the volume of water flowing through the pipe. The water pressure would be the voltage. Watts would be the power (volts x amps) the water could provide (think back to the old days when water was used to power mills
That's right It is current that is "supposed" to pop a fuse. I could be wrong
Once I thought I was wrong, but it turns out I was mistaken LOLOL
As stated, the amps don't care what the voltage is in terms of the fuse blowing.
