Anyone Use KB109's With Stock Heads
Drg racr
East Central Indiana
Just wondered if anyone has used the KB 109 popup pistons with stock smog heads. Mine are the 4051 heads, going on a 1972 360 block with stock crank/rods. Thinking of having the heads ported, cleaned up and milled for better springs and adjustable valvetrain. I don't have cash for a $2K set of heads.
Do you mean KB190 pistons ? I am running them with 308 heads on my 360 in drag car.
kb191 which has a larger dome then the 190...used them on a set of highly milled J heads..
Tony, 191's or 190's with the J heads?
kb191....with dome...and heads cut to 61 cc....that baby had some compression..
