I built an engine with basically the same needle bearing Chinesium rockers (these were "C.A.T." brand, but they all look the same and have "NSK" bearings) years ago for a friend. We used a moderately aggressive Lunati solid FT cam (254/264*@.050",.588/.570") and ISKY 8005A dual springs in his 446" RB with iron heads and dome pistons. Ran great and no rocker durability issues. On a refresh years later, the #4 main showed some excess wear, but the block mains mic'd true, so I attributed the wear to oil volume loss from the rocker feed passages and the open needle bearings in the rockers. Converted to full-time rocker oiling and restricted the feed to the rocker shafts in the heads to .042", hoping to keep more oil on the #4 main journal. I did also replace the adjusters with Crane units, out of paranoia more than an actual issue. So far so good.
