Are Mopar small block heads interchangeable left to right?
cudafish
New Member
Quick question, Can you swap Small Block heads from one side to the other or is there something special about each head?
Thanks for the help
Cudafish
I know that some of the aftermarket heads may need some minor machining to provide clearance for things such as alternators, p/s pumps, and even the LH stock exhaust manifold. If that was done, like on my Edelbrocks, they will no longer be interchangeable sise-to-side.
If one head has a bad threads where the alternator bolts on,it becomes the drivers side head.
I was going to say to check the threads because of exactly that, but now I'm not going to. :)
The LA engines (273, 318, 340 & 360) have heads that are the same.
I know some of the current Chrysler engines (4.7l V8) has a left & right head.
