Are these....
RPMLegends18
Modesto, CA
out of an A-body? Also if not, which clutch pedal assemblies will work other than A-bodies? Will B or E body stuff work? Are they year specific? I had a guy tell me that early A, 67-69, 70-72, and 73-74 are all different and non interchangeable, of course I don't know anything about it so I just kinda nodded my head.
Also I looked for P/N's and could only find one, it is 155M132. It was on the bracket in picture #3.
Thanks,
Ryan
Probably from a 67-69 A body.
Will work in ANY 67-76 A body car. Lacking the clutch safety switch for 70+ applications
Sweet, thanks cracked...is the brake master cylinder the same? Or does it use a different master cylinder
As mentioned above, it is the same up to 76 but correct for the 67-69
It will also bolt in and work in the early A-body, the difference between the 66 back and the 67 up pedal assembly is the clutch and brake pedals drop down on both sides of the column on the 64-66 but on the 67 up they drop down on the same side of the column but they will fit and work in either early or late.
