73 dart sport
Work To Live
On the rear main the oil pump resides over one of the main bolts. The ARP studs are way too long. I have looked at every possible solution and dont really like any of them. Any ideas???
GoodysGotaCuda said:you have to use a factory bolt there.
73 dart sport said:Thanks, That's what I ended up doing.You would figure ARP Fasteners would fit the application....Guess not. :salut:
340mopar said:I cut shortened my stud and run the 12 point nut without the washer. The reason it does not fit is that the ARP stud kit also fits the B/RB and the stud in question would work fine on those motors. If you use a bolt use two because the clamping forces for the studs and bolts are differnent.
Chuck
73 dart sport said:I'm not building a stroker or extreme 318 just a good dependable running driver.
moper said:So? You went thru the expense of buying the best parts. And those parts cause a ripple effect that the right machining will fix. You could be building a Honda, or a stock 1bbl225/ and the fact remains. You would have been better served by re-using the old bolts. If it's a stock rebuild, I would have done that. Just me tho...
1969340dart said:`I was reading an article where by using a stud kit it helps decrease crankshaft deflection due to the fact that it holds the main cap better in position than a regular bolt. I have not heard of having to have it linebored because you use a stud kit.I am actually having an engine built and am using a stud kit so I wil talk to the machinist to find out more information on lineboring. Glad to run across this topic. Any more surprises I may run into!
Bobby
