pntastar69
What ARP head bolts and or studs are needed on a LA 360 w/Speedmaster Heads PCE281-2146? Recommendations bolts or studs? Street car only.
Got it, thanks. Would the bolt kit be 144-3601?ARP 144-4005 is the stud kit that will work. Same as Eddie heads
YesGot it, thanks. Would the bolt kit be 144-3601?
Yes 144-3601 . Has the two additional long bolts required with the Speedmasters , Edelbrocks and W2s. This is what I used on my Speedmasters. The 3602 mentioned above is for stock stock heads.Got it, thanks. Would the bolt kit be 144-3601?
