Uncle Bob
Shiny paint causes stress.
I'm guessing these studs will work with any windage tray, but am sure wondering why there are 5 long studs in the kit when there are only four bolt holes in the windage tray?
Thanks for the link. It looks like a PITA no matter what parts I use. It's tempting to just not use a tray since I don't already have one.You only need 4.
Windage tray with ARP
Milodon sells a kit with only the 4 studs/nuts needed to mount the tray.Not sure mixing studs and bolts is a good idea.
If I have to do that then my decision is made because the machine work is already done. I'm not signing up for that aggravation again. Months of waiting and TBH disappointing work when I finally did get my block back.If your building the motor, mock this up and have the block aligned hone with the stud or mix of studs and bolts.
Pretty much.I guess if I can't find the impossible to find factory bolts then studs are my only alternative?
Question, does ARP supply the torque value for the fine thread?Pretty much.
And I'll get flamed for saying this, but I wouldn't overly worry about line honing the mains with studs. Mic the saddle bores across a few different axis to confirm if it concerns you too much.
Just adhere to the recommended torque values for the studs (not the bolt torque)- fine threads exert greater pressure on the caps than coarse threads and can distort the bore if exceeded.
I believe they did, it's been a while since I used a stud kit. My notes say 70# with moly lube, 80 with engine oil- but I would contact them to confirm.Question, does ARP supply the torque value for the fine thread?
