from 1972 to 1976 all Dart dash frames - Custom, Swinger, 2 and 4 door are all the same for similarly equipped cars and have the same instrument cluster hole. The one I used was in a 1974 4 door Dart Custom. I don't know that dash frames for Dusters, Demons and Dart Sports, which all share a different body from 2 door hardtop Darts are the same, but someone here does and I think that is true. The holes in the dash frame for bezels (plastic trim) may vary, especially the glove box door. If you are going to post a wanted ad, best to ask for pics and compare all the accessory and trim holes (although they can be easily welded up or drilled where you need them). All the a-body dashes from 67-76, except for 1968, have interchangeable dash pads, though the grain changes from year to year.
