Hi,Can you guys post some pictures of how and where you ran your sending units for oil and temp? I know it has been talked about but im more of a visual person.
Mine are the same as this! Actually I think I used RealWing's pictures for reference.Oil pressure and water temp using '69 Barracuda factory senders to stock gauges. This is a 6.1 Hemi.
I don't see the oil temp gauge. Where is the sender located?I made a tee. I'm running an oil temp gauge and a mechanical oil pressure gauge.
