Axle bearing adjustment
Transmission and Drivetrain Tech
  1. dan5354
    dan5354 Well-Known Member
    76
    11
    Apr 27, 2014
    Orland Park.IL
    Local Time:
    6:43 AM
    I am trying to adjust my rear axle bearings in an 8-3/4. I find that i get an up and down play before I get any end play. Any help here would be appreciated.
  2. dadsbee
    dadsbee FABO Gold Member FABO Gold Member
    855
    1784
    Nov 25, 2020
    Penetang, Ontario
    Local Time:
    7:43 AM
    All I've got from doing mine..
  3. dan5354
    76
    11
    Apr 27, 2014
    Orland Park.IL
    Local Time:
    6:43 AM
    If I adjust all of the end play out, I still have an up and down play in there. Could a bearing have seized from a previous owner and ruined the housing? I checked the O.D. of the race with a new one (with a micrometer) and they are the same.
  4. dadsbee
    855
    1784
    Nov 25, 2020
    Penetang, Ontario
    Local Time:
    7:43 AM
    I noticed my Dart (my Bee shown in video) had that , a bit of up/down play before I tore it apart. Had none when I put it all back together with everything cleaned up and the bearings repacked. Not sure what the clearance spec on housing to bearing cup diameter is supposed to be, but once loaded and on her tires it shouldn't be a real issue unless the play is severe.
  5. dan5354
    76
    11
    Apr 27, 2014
    Orland Park.IL
    Local Time:
    6:43 AM
    Thanks - I have pretty much confirmed the housing is worn. There has been work done on the diff in the past. The only reason I got into it in the first place is - the seal on that side leaked, so I replaced the seals. I noticed the slop when trying to adjust it then. It's about . 025 . I do get a clunk from the rear when it upshifts in to second. I think I'll pull it once more and check itvwith an inside micrometer. I wonder what the tolerance is supposed to be.
  6. dan5354
    76
    11
    Apr 27, 2014
    Orland Park.IL
    Local Time:
    6:43 AM
    I get a difference of .052.
    Weird idea - do they make an O.D. oversized race?
  7. Dicer
    Dicer Back Bone beats Wish Bone all the time. FABO Gold Member
    1,348
    1917
    Jan 12, 2016
    Land of Lincoln
    Local Time:
    6:43 AM
    I would look into and consider using "Green" axle bearings. Dr Diff has an excellent web site, and there is a lot of info on this site as well for their usage.....
    • Agree Agree x 1
    • Daves69
      Daves69 Well-Known Member
      5,620
      3971
      Feb 20, 2011
      WestOfChi
      Local Time:
      6:43 AM
      So is the race play up/down only, not front to rear. Does both axles have the same issue?
      • Like Like x 1
      • Dana67Dart
        Dana67Dart Like a fine wine, only getting better with age! FABO Gold Member
        6,297
        4130
        Jul 16, 2017
        Northern Colorado
        Local Time:
        5:43 AM
        If the play is up and down and the same front to back you could get some shim stock and make a cookie cutter shipped shim the take up the slop. Probably stainless steel would be a good choice
        • Agree Agree x 1
        • oldkimmer
          oldkimmer FABO Gold Member FABO Gold Member
          19,049
          6301
          Nov 11, 2006
          Kindersley, Saskatchewan,
          Local Time:
          6:43 AM
          I would get new ends from Doctor Diff if u have that much play. Kim
        • RustyRatRod
          RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
          71,464
          46588
          Jun 7, 2010
          Georgia
          Local Time:
          7:43 AM
          This is also my recommendation.
        • Dana67Dart
          6,297
          4130
          Jul 16, 2017
          Northern Colorado
          Local Time:
          5:43 AM
          For the cost of the ends, welding, streighting, you could have a machine shop enlarge the bearing seat area and make you a shim.
        • dan5354
          76
          11
          Apr 27, 2014
          Orland Park.IL
          Local Time:
          6:43 AM
          There is also front to back play besides up and down. Green bearings will have the same issue.
          I am thinking new housing from Dr. Diff. , but his website says they're out of stock. I emailed him to ask a few questions and haven't heard back.
          Any thoughts on finding a good used one? I found one somewhat close to home for $600. A new one from Dr. Diff. Is only about $100 or so more. Both have axles, but the used one has small bolt pattern that I want to keep.
        • pishta
          pishta I know I'm right....
          19,801
          9180
          Oct 13, 2004
          Tustin, CA
          Local Time:
          4:43 AM
          How about an old fashioned .013 shim around the race? The bearing would draw the race in nice and tight against that and it could last for years. That's what Farmer John would do to bring in the last harvest......
          • Agree Agree x 1
          • MOPAROFFICIAL
            MOPAROFFICIAL FABO Gold Member FABO Gold Member
            7,715
            6922
            Jun 1, 2016
            Beach
            Local Time:
            4:43 AM
            Nah... BFH!
            Jk
            • Like Like x 1
            • MOPAROFFICIAL
              7,715
              6922
              Jun 1, 2016
              Beach
              Local Time:
              4:43 AM
              @RustyRatRod
              Been a long time since I've read "BFH"
              ...So i thought i would carry the torch.
            • RustyRatRod
              71,464
              46588
              Jun 7, 2010
              Georgia
              Local Time:
              7:43 AM
              LOL
            • MOPAROFFICIAL
              7,715
              6922
              Jun 1, 2016
              Beach
              Local Time:
              4:43 AM
              As for Axel end play, I just tighten it so I can feel it move... but can't see it move.
            • RustyRatRod
              71,464
              46588
              Jun 7, 2010
              Georgia
              Local Time:
              7:43 AM
              Similar to how I adjust ring gear back lash.
              • Like Like x 1
