Axle Bearings
71Duster
Alberta Canada
Needing a new axle bearing for my 8 3/4 it has the aftermarket bearing without the adjusters on them, any idea where I can pick one of these up short of phoneing strange or moser?
Damn always gotta get stuff outta the States, kills me on shipping, was hopeing to have parts by the next week for a year end BBQ, going to check that website tonight, thanks.
Why don't you go back to the old tapered type bearings? They are available at your local bearing store. Here are the parts needed.
2ea - 15460 inner seals
2ea - 19000 outer seals
2ea - BR7 bearings
1ea - A7-LK Left retainer
1ea - A7RK Right retainer
These are a better bearing anyway as the green bearings won't take the cornering loads that these will.
If you need help installing these, let me know.
I just read all the stuff about the tapered bearigns being such a pain to set up, But it would be cheaper most likely. ~Not that I like to go sideways around corners~ May have to plan a trip up to whitecourt with the Duster before the snow flies. You never e-mailed me back about the column and driveshaft though.
