340plot
the bushy bush
i just picked this up today. it is a 71 scamp with a 65 383 hp engine with 73 hp c body manifolds. 727 trans, crossmember, sbp a-body 8.75 rear,it now has a 3:23 open chunk in it. driveshaft, all linkages for the colunm shift, k-frame has been modified to put the engine in the car. i do not believe it is a stock a-body b.b k-frame.
the car itself is not for sale. just the entire running gear assembly.
it turns over freely. i will be putting a dist cap on it in the morning, as i had to order one, and will tell you how well it runs. i see no metallic particle in the oil.
1,800.00 located 30 minutes from martinsville international speedway in va
