Thats the easiest one to make fit an a body. You just need correct linkage and shifter mounting plate. Might be interested in trading you your b body stuff for a body that will work for your application.
You will be able to use your original a body linkage if it has enough adjustment. Yes your mount plate will bolt up but will put the shifter at a way forward facing angle coming through the floor.
