B body trans in A body?
batoven
Washington State
Will a B body 904 auto fit in an A body with no modifications? I thought I read somewhere that the tail shaft/housing is longer on a B body 904?
67 and older use a different converter than 68 and up so keep that in mind.
Obviously irrelevant in the A904 discussion but I believe that the bell housing for big block vs small block would be a consideration if you were looking at 727s.
