GTGrinly Well-Known Member Joined Jun 2, 2006 Messages 1,497 Reaction score 38 Location Central PA Jul 3, 2018 #1 Anyone use this B&M and have trouble with alignment of converter bolts?
brian6pac Legandary Member Legendary Member Joined Nov 15, 2016 Messages 5,668 Reaction score 4,099 Location N.E.Ohio Jul 3, 2018 #2 only goes one way, you have 4 combinations
Divenut Well-Known Member Joined Sep 22, 2011 Messages 3,567 Reaction score 1,841 Location Naperville Illinois Jul 3, 2018 #3 I had to turn the flexplate several times to get all four holes to line up. I numbered the holes on the converter with a sharpee to help me track the attempts/combinations. pat
67Dart273 Well-Known Member Joined Oct 14, 2010 Messages 60,848 Reaction score 34,482 Location Idaho Jul 3, 2018 #4 Well what are you bolting it TO? For all I know you have a Ford Y block adapted to a Chevy powerglide. But if you are using a Mopar OD transmission, those have an "even pattern" bolt pattern.
O oldkimmer FABO Gold Member FABO Gold Member Joined Nov 11, 2006 Messages 24,984 Reaction score 9,099 Location Kindersley, Saskatchewan, Jul 3, 2018 #5 No problem at all when used for it’s intended purpose. Kim
