B&m megashifter cable way to long
Dodge74
sunny FL
5 ft cable way to long!!! What to do??? Maybe move the shifter back more. Need help..................
Thanks........................ PETE...........................:?
The cable on my star shifter was way to long just loped it around and it works fine.
buy a shorter cable would be the best solution. although looping it will work, it might cause it to bind up slighty and not move as smoothly as it should.
i have a brand new 3 ft cable if you are interested. It has been installed but was too short. Here is what the ends are like on it.
Thanks for all the help...........................................
