B&M Super Street Charger Hydraulic Camshaft
68Darthawaii
Waianae, Hawaii
B & M Super Street Charger complete:
Hydraulic Camshaft, Lifters, and Valve Springs
Mopar small block 273-318-340-360.
.504 intake lift and .528 exhaust lift at the valve.
288 duration intake and 298 duration exhaust
Has anyone heard of this cam or using this right now???? Also what requirements would I need to make this cam work with my LA 360. Thanks!!!! Any info will be helpful!!!!
That's a pretty big cam. I would definitely check valve guide clearances just to make sure. Hughes recommends anything over .510 lift needs to have the valve guides shortened to keep the valve spring retainer from hitting the top of the valve guide, and also valve to piston clearance as well. You should have atleast 9.5 to 11 or more compression ratio before running that cam. I could be wrong but that is what I would do if it was me.
Thanks for the advice!!! I won't be rushing to put it in yet. Til I research it first. :)
