forced 340
This is a pro rebuilt big block mopar transmission(361, 383, 400, 413, 426, 440) among others. B/RB engines. Its a standard pattern valve body with kick down, 4 disc clutch pack w/red eagle friction and kolene steels, raybestos pro band, 4-pinion h.d. planatary, new TCI bolt in sprag, governor is upped to hemi speed(higher up-shift). Zero miles on the trans. Was installed for engine break-in and the engine failed (no oil pressure). Ran for 5 minutes. Asking 900 o.b.o.will consider trading for 70' 340 swinger parts or small block parts. pics upon requests. i have one of the builders transmissions in my dart now and it is perfect! he built the trans that was in my 1200 hp dart as well and there are a few others in this forum that have transmissions built by him. pick up or meet somewhere only. will not ship. thanks guys! trans only no converter. located in redford mi. 48239.
