[SOLD] B/RB mid plate support
physixx
Edison, NJ
I have a very nice engine/transmission mid plate support for any of the B/RB engines. The width of this plate is 26 5/8” and measures approximately 3/32” thick. Since this mid plate will move the trans back the thickness of the plate, I am also including the spacer for an 8 bolt crank that goes behind the flex plate so that the convertor will be in the correct position in the trans pump. For the 6 bolt crankshafts, washers can be used between the flex plate and the convertor equal to the thickness of the mid plate so that the convertor will be in the correct position in the trans pump. I’d like to get $40 plus the shipping.
Ken
Edison, NJ
