Back from Martin with a new best
10secdemon
Active Member
got the Demon to a 10.12 et in 1/4 in street trim thru the mufflers. car hooked good with the wheels in the air :supz:
Bob
Wow, thats impressive. Wonder if you could get it in the 9s? Good job. Mike
with a little more tweaking on the ladder bars to leave higher on the trans brake, should go high 9's :thumbup:
my 60 ft's where 1.43/1.44 should be high 1.30's
Bondo
WOW !!! What a day you must have had.
You and the light as one.
A great pass you will never forget.
Congratulations Bob.
What engine you runnning?
feels good to start to sort my combo out. it was the 5th time i had the car out with the new motor.
I run a 362 ci small block N/A no power adders ! with mopar W5 heads. ran the car across the scales there. 3205 lbs. I had my Indy intake on for this weekend. small blocks rule ! thanks guys Bob
