Back in the game. Parts needed
68 Sedan
Rating - 0%
0   0   0
Okie dokie. Things came to a screeching halt for a while on the Sedan, but with the exit of the runner I'm back in the game. But that screwing around with the first "buyer" (and I use that term loosely) it cost me a COMPLETE trans setup, including all the linkages AND the reverse light. (%&*$%@#)
SO
I need a 4 speed setup complete, or as close to it as I can get. Would prefer an aluminum OD, with shifter, all linkage, bell, "Z". Everything but the pedals.
Both my front fenders have rust at the bottom. Right one is worse. Looks like someone used a ball peen along the top of it.
Hood. Got a glass hood you decided to take off or not use? Got a SCOOP? Ok, I guess another flat steel hood will do. No rust. I have one of those.
Tail lights. I need some nice tail lights. Both of them complete.
Rear bumper. Fresh or needing chrome ok. Just need straight, with no rust.
V8 throttle cable for 4V if there is a difference.
Fan shroud for V8 round top radiator (plastic shroud that is)
Dash pad. Uncracked, or at least not so bad it can't be covered with a cap.
LD340 OR LD4B intake. I scored the Eddy heads, but still don't know if I'll use them. So if I get an LD4B then I'll just use the 318 as a 318. LD340? Stroker!
There is a LOT of other stuff I'm gonna need, but may just buy new. Things like front door panels, maybe arm rests, main under hood wiring harness for a V8. Who knows.
This is all for my 68 Dart Sedan, and I'll be looking at spending money starting FRIDAY!
Thanks in advance
You should be able to open the LD4B up to 360 port size. Pretty good intake.
I think we've been playing a little "tag" in your thread about it.....the dash etc. Tomorrow I'll look inside mine to see what I need
I used a 318 2 bbl throttle cable from a 73 Duster, works great on my 66 Valiant 340, I also used an adjustable throttle bracket for the M-1 intake.
Thanks for the responses guys. I'm starting to get a bit caught up after taking care of sending the runner to it's new home, then house sitting for my lil sis. I've already contacted a couple of you and will be taking care of things tomorrow (Tuesday).
Thanks for the info on the cable, Keith. Guess I'll have to look for one of those, since all I have is the original /6 piece in the Sedan.....at least I think it's still there......I know there's no speedo cable. Guess that's ok....since there's no trans to hook it to#-o
:dink:
I'll be going to the Dallas Mopar show in a couple of weeks doing a little "shopping". If anyone is going and has something I might need, let me know
